My Canon Printer is Not Printing Black. Why?
marthasmith
Post by marthasmith » Fri Apr 27, 2018 6:35 am
People when work officially, mostly desire Black and white printouts. And that will be very annoying when they don’t get when they want a black printout. And when your Canon Printer won’t print Black, you should unplug your printer and reconnect it after some time. Then, try to print a test page and if the problem still goes on, consult the printer’s user guide for best instructions. When the problem still persists, you should get in touch with the technical representatives at 24*7 Support For Canon Printer in the UK on an immediate basis. They can be trusted for the easy assistance from the well proficient technicians. To know more you can visit here :- http://contact-help-number.co.uk/canon- ... number.php
ElenaPontedra
Contact:
Re: My Canon Printer is Not Printing Black. Why?
Post by ElenaPontedra » Thu May 24, 2018 11:53 am
Thank you for this information. You helped me a lot with this printer.
shahid139
Post by shahid139 » Sat May 26, 2018 5:54 am
I am also facing the same problem which you are facing here because it does not support black due to the low machine of this printer.
PaperCoach
Contact:
Post by PaperCoach » Wed May 30, 2018 11:41 am
Thank you for this post. This is very interesting information for me.
Blackjack
Post by Blackjack » Tue Jun 12, 2018 7:41 am
First, please make sure that the installed ink tanks are correct and full of ink. The correct order is:
CLI-251M magenta
CLI-251BK black
CLI-251Y yellow
PGI-250BK black
CLI-251C cyan
Next, please print the nozzle check pattern to determine whether the ink is ejecting properly from the print head. To do this, please follow these steps:
1. Make sure that the machine is turned on.
2. Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
3. Open the Paper Output Tray and then open the Output Tray Extension.
4. To print the nozzle check pattern:
4-1. Press the MENU button.
4-2. Press the Setup button.
4-3. Select Maintenance, then press the OK button. The Maintenance screen is displayed.
4-4. Select Print nozzle check pattern and then press the OK button. The pattern print confirmation screen is displayed.
4-5. Select Yes and then press the OK button.
The nozzle check pattern is printed and the pattern confirmation screens are displayed alternately. Please compare your printout to the example that has been attached to the bottom of this post.
If they differ, perform a few cleanings. Please perform the following steps to perform a Cleaning:
3. Select Maintenance then press the OK button.
4. Select Cleaning and press OK.
5. Press OK to select Yes.
The cleaning will be performed. After 2 or 3 cleanings, print another test page.
Does the test page print correctly?
________________________________________
http://gotblop.com/
