How may you recover Google account with the help of alternate email address!
helpinfo
Post by helpinfo » Thu May 17, 2018 7:04 am
Google is the leading search engine which has become the popular search engine as it renders prominent features to its user.To access Google related service,user are required to create account on it.After that you can use the Google account.
When you use Google account then there might be possibility when you may face some technical issues while using the services provided by Google.There can be so many reasons when your account does not work in a proper way.Out of all these issues “forgetting password” is one of the common issue.We are describing some steps for google account recovery by alternate email address.You need a look on these steps.
Go to the Google account recovery page.
You need to enter the email id and password.
If you have forgotten the password then click on the”Forgot password” link.
Here you need to select the option by which you want to recover the password such as with the help of alternate email id,via phone number or with the help of security question.
If you want to recover the password with the help of alternate email id then click on this option.
Here you need to enter the alternate email id in the given field.
You will get a link on that email id,you need to click on the link.
Once you click on the link then you will be move to the email account recovery page.
Here you need to enter the new password ,make sure this password should be strong so that ,it would not be recognized from others.
You need to agin enter the password for confirmation.
After that your account will be open.
Now you need to logout your account ,again login your account with new password.
If you face any issue then you do not need to worry about it ,you need to take help from Google support team.Google provides highly experienced technician to resolve all the issues.They will never let you down to support you.
Source : http://www.gmailtechinfo.com/how-to-rec ... nate-email
