Error 13 always pop out since May 21
sis
Post by sis » Sun May 25, 2014 2:33 pm
Hello, there is something wrong with the vpngate on my computer. Since May 21, when I connect to the servers in the vpngate list, sometime it 's successfully connected but the network icon on the system tray shows no internet access and there is a yellow exclamatory mark on the icon, after a few seconds it will disconnect automatically and shows error code 13, like this
Error (Error Code 13):
Time-out occurred during VPN session communication. It is possible the connection from the client to the VPN Server has been disconnected.
sometime it 's successfully connected without a yellow exclamatory mark on network icon on the system tray but the network not working can't surf any website and after about one minute it will disconnect automatically and shows error code 13
No matter how many times i tried restart computer or shut down the computer power, the problem still exists. But some servers work fine, it can connect and works like normal, while most of the servers fail. I don't know if that's the modem problem or the vpngate problem, but it works fine without connecting to the vpn on my computer , it seems the modem is ok. I tried download the latest version vpngate on the official site and reinstall it, problem still exists.
I have try some other vpn service, for example some openvpn, all work fine without the problem mentioned above, and that problem just happened recently, vpngate works very well before, I think it's really the vpngate problem, but I can't find anyone post the similar question here anyone help fix the problem.
I am using windows 8.1 64bit and the latest version vpngate build 9437.
smile2
Re: Error 13 always pop out since May 21
Post by smile2 » Mon May 26, 2014 8:16 am
yes. I found same Error 13 when connect to most of servers.
before several days, all to Japan servers connection report Error 13.
but recently most of all country shows Error 13,
connection always been disconnected less one minute.
mppbee
Post by mppbee » Mon May 26, 2014 2:42 pm
i too can connect to any servers on vpngate server lists.
they connect but don't do anything at all.
it doesn't change my ip ether.
but it doesnt give me the error 13.
does softether vpn still works?
i made and no one is helping me too.
Please help us.
smile2
Post by smile2 » Wed May 28, 2014 9:10 am
Fine, I found a way to finish Error 13.
send email to me 4f4fd49d@opayq.com, I may reply to you.
smile2
Post by smile2 » Wed May 28, 2014 9:59 am
I received a problem about ip doesn't change after connection.
I don't know why it happen. I think your network environment was very unique.
dnobori
Post by dnobori » Thu May 29, 2014 4:44 am
Where is your country?
sis
Post by sis » Fri May 30, 2014 1:47 am
I am in China, Since May 21 and the problem still exist every day till now, I can hardly find a working server, 9 out of 10 encounter the problem I mentioned in the post, how to fix the problem ?
dnobori
Post by dnobori » Fri May 30, 2014 3:44 pm
In China, there is Great Firewall. Perhaps GFW staffs are doing good jobs.
sis
Post by sis » Sat May 31, 2014 2:01 am
Hope your team of elite will solve the problem of Error code 13, the Vpngate is a very great free tool to bypass the restraint in China, the speed is better than many pay vpn, but 9 out of 10 servers encounter the problem posted and I have to use the pay vpn one day, that's bad, hope you can fix the problem thanks very much
shen69
Post by shen69 » Sun Jun 01, 2014 11:58 am
@dnobori
WOW! Seriously? So this is your response? That we should congratulate the Chinese staff taking care of GFW ? What is the point of a VPN that would be blockable by them? This kind of response is ridiculous. They have been doing their best for years... and havent' stopped stuff like Freegate not to mention this and you're telling people on this board that the problem might be because of China? OMG... what a lame answer.
sis
Post by sis » Mon Jun 02, 2014 3:23 am
hi shen69 do you have any free or paid vpn recommendation , the vpngate no working anymore in China, I can hardly find a working server, I try some free vpn and the speed is very slow can't even load a website like google, but many paid vpn get negative comments, eg, some users say hidemyass sometime no server working and with slow speed, hope you introduce a good and not too expensive vpn service
shen69
Post by shen69 » Tue Jun 03, 2014 8:43 am
@sis
Wish I had. I've been using mostly Freegate, Ultrasurf and some website proxies which don't have full usability. Like ninjacloak.com but that's not good for Facebook or Youtube.
Now with OpenVPN stuck it's a bummer. Well on the plain openVPN from the openvpn.net when I get the config files from some servers from the list on Tsukuba it can work... for few hours or so on UDP... but then next day it won't. Been using OpenVPN for over half year and till recently everything was fine and dandy.
SoftEther is better at the moment with their SSL-VPN but many servers are terribly slow and unstable for me.
Also make sure you use a proper dns like the google or opendns one.
I tried stuff like Tunnelbear and other vpn programs but they didn't work at all. So only that openvpn and this softether really did some job. Maybe websites with their private servers would be more reliable, outside of Tsukuba's project? Try freevpn[dot]me
Which surprisingly isn't blocked in China... but I couldn't ever get good speed there. There's also VPNpassport also worked in the past but haven't used that for months.
Someone on this forum from Beijing said that SunVPN (only paid option available) might be good. So if you want to try a paid one might wanna give that one a try.
Regards.
internet freedom
Post by internet freedom » Fri Jun 06, 2014 4:22 pm
I have the same problem or rather I have two. error code 2 and error code 13.
Has anyone got any answers to these two problems. I have two other VPN services that I can fall back on. Cheers
sis
Post by sis » Fri Jun 06, 2014 4:55 pm
The VPNGATE is no longer working in China, most servers get the error 13 problem, you can hardly find a working one, some openvpn configure file on the homepage is working but not stable, it may stop or disconnect anytime, and the vpngate staff seems not going to fix the problem as the problem exists for almost a month, I think we should share the other working and good vpn in the forum so users in China can still break the network restraint without the vpngate, I tried most free vpn I found in google, just ultrasurf is working sometime, others is either unconnectable or with very slow speed can't even load a webpage, have you some good free vpn with fast network or the good paid vpn recommendation, as you said you have two other vpn services , can you share here
internet freedom
Post by internet freedom » Fri Jun 06, 2014 5:42 pm
I have this problem. looks like the clowns operating the silly GFW might have something to do with this problem. try www.zenmate.com it's a free google plugin and encrypts everything. watch youtube. facebook and any other site. even in China.
internet freedom
Post by internet freedom » Fri Jun 06, 2014 5:48 pm
Another VPN worth trying is Astrill. use it is stealth mode or open web and set it to port 443 and tick the proxy box in the middle. you also have goagent which is free.
sis
Post by sis » Sat Jun 07, 2014 11:12 am
I tried the Astrill trial and I don't think the speed is good enough, and it just offers few servers for trial so I don't even know if every server is connectable, and it's a bit expensive, as for goagent it's too complicated and seems it has bandwith limit, have you try hidemyass, it seems very popular but I never try it, I can see some bad comments on hidemyass vpn, can you share some information about hidemyass
noname.verified
Post by noname.verified » Tue May 01, 2018 7:39 am
its about you network adapter is unpluged or not responding, please check your adapter first. Control panel>Network and sharing center>change adapter setting, then connect the VPN.
