"Only a few minutes connection" VPNGate server OPTION
Tokushima
Post by Tokushima » Sat Jun 28, 2014 7:44 am
I hope that you make enable "Only a few minutes connection" VPNGate server.
It means the VPNGate server terminates all connection after a few minutes.
I only use VPNGate to listen to the internet radio service "Radiko" in Japan.
You can play "Kyoto prefecture Radio station" in Radiko if your PC is located in Kyoto prefecture.
I want to play "Kyoto" radio station but I have stayed in a different city.
"Radiko" service only check the location of you PC for a few seconds since your PC starts "Radiko" application.
So I need the VPNGate only for a few seconds until "Radiko" service recognizes that my PC is located in "Kyoto" City.
If the VPNGate server application has "Only a few minutes connection" option, I will connect a volunteer server which the option is "ON".
