In simple terms you can't, the VPNGate functionality of SoftEther VPN for linux is not enabled and it probably won't compile if you tried to enable it let alone work properly.
A similar thread discussing this is available here:
viewtopic.php?f=11&t=3828#p9103
How to add your OpenVPN Centos
Re: How to add your OpenVPN Centos
As BoredAus said, at the moment, the "easiest" way to go is open up a windows virtual machine on your centos server and run the VpnGate plugin because it's not available for Linux.
