The first thing always in troubleshooting is to try and trace back what you did last that may have caused this to happen.
Failing to recall anything that may have caused this to happen, the next thing would probably your firewall setup and/or services being disabled. With firewall setup, first temporarily disable your firewalls to see if the issue persists. If the issue persists it could be DHCP client being disabled or filtered somewhere.
