Hi guys,
I am studying vpn, and I want to understand how VpnGate and SoftEther VPN work.
I have problem while trying to connect to a vpn manally
1. I choose a vpn in the list: http://www.vpngate.net/en/. For e.g. vpn931679014.opengw.net / 184.22.176.241 from Thailand
2. I open SoftEther VPN client manager, choose "Add VPN Connection" => then fill all information to Host, Port, Hub, Authentication
3. Click OK, but the software can not to VPN
But if I use "VPN GatePublic VPN Relay Servers", then select the same vnp as above (184.22.176.241 from Thailand), I can connect.
I attached two files, they are Property page of the two connection
1. Connect manually.PNG => Fail to connect
2. Connect from list.PNG => Select VPN in list => Connect ok
I am looking forward any comment/ideas, they will all help me to understand this situation.
Thank you in advance,
