determining ip address
mojamba
Re: determining ip address
Post by mojamba » Tue Jan 10, 2017 4:37 am
I am having the same problem. Did you every find any solution? Anyone else having the same problem? Perhaps it is related to something in Windows 10 (my platform), though I cannot guess what that might be, especially since the initial connection is made. FWIW, I am generally unable to connect via TCP and can only do so via UDP, so perhaps that is somehow related?
mojamba
Post by mojamba » Wed Jan 11, 2017 11:53 am
I have found a solution that I will share. Not sure if it will help you or not but I think it might. What I did was simply to delete the Virtual Network Adapter and create a new one. I am not sure why the original wasn't working but perhaps it somehow got corrupted during a Windows 10 update? Anyway, so far it seems to be working reliably again so give it a try.
