Do You have 500 and 4500 udp port forwarded to Your serever?
You need it,
and password, address, port, ipsec pre shared key
and
working local brdige to get IP
If You have all of them, You should be able to connect
have a nice day
R
Can't connect to VPN with my android.
djago
Re: Can't connect to VPN with my android.
Same here. S5 with Android 6.0.1. Ports are forwarded and all other req are met. Any clue?
Naveen
I could connect my Nexus 5 (6.0.1 ) to softh ether .make sure ur vpn server and phone are on same network . try to ping from ur phone to server first .(use PIngTools from playstore )
Please follow below steps
1.Name : any name u can giv
2Type:L2TP/PSSecPSK
3.Server address: VPN server IP
4.L2TP : not used
5.IPSec Identifier :not used
6.IPsec pre shared -key : present in Softether VPN server settings (IPSec/L2TP setting)
7.DNS search domains ,DNS Servers : not used
8.Forwarding routes:0.0.0.0/0
and Save.
Click on ur vpn connection enter user and password that u created in VPN server Manager .
If it is unsuccesfull,go to VPN server manager goto ur VPN hub settings and click on Virtual NAT and Virtual DHCP server ..and enable secure NAT .
Then try again from ur phone.
Let me know if u face any issues still ..
2Type:L2TP/PSSecPSK
4.L2TP : not used
and Save.
