It is currently Sun Aug 20, 2017 12:25 am
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Need some help.
PostPosted: Mon Dec 26, 2016 8:14 pm
So, I've started using SoftEther Vpn, And i only have one problem
I can connect to any server, expect the russian and the ukraine ones, it just says that it will try again.
Please tell me what to do!
-TeZhh
File comment: What i see.
Top
 Profile
 Post subject: Re: Need some help.
PostPosted: Tue Mar 28, 2017 9:12 pm
I had the same problem.
I have deleted all the folders and reinstalled the program again, but the same error code 2 appears no matter which server was selected.
Are there no one who is capable of solving this nagging prodlem?
Top
 Profile
Search for:
Jump to:
Return to www.softether.org
