Error (Error Code 1
Pandora-Box
Re: Error (Error Code 1
Post by Pandora-Box » Wed Feb 22, 2017 5:58 pm
Hi rooster1,
you probably will have to be more explicit and provide more details.
From what you wrote, it appears you might have plain OS internet connection issues.
If using Windows, internet icon with a yellow exclamation sign shows problems with network connectivity, including internet, but OS-level problems not vpn (softether does not have icons with yellow exclamation sign).
What do you mean: "My modem is being diverted to my wireless USB adapter"? This does not make sense. WiFi adapter should get connected to your modem, not the other way around.
How does your wifi adapter get connected to internet?
Definitively, more detailed description of the problem and network setup needed.
Good Luck
P-B
