How can i fix this problem
SALICHAM
Post by SALICHAM » Wed Feb 22, 2017 10:59 pm
please help me
how can i fix this problem (in the picture)
Pandora-Box
Re: How can i fix this problem
Post by Pandora-Box » Thu Feb 23, 2017 2:15 pm
Hi SALICHAM,
are you sure you are downloading and installing vpngate client from http://www.vpngate.net/en/download.aspx or from its mirrors: http://www.vpngate.net/en/sites.aspx and not plain softether vpn client, which lacks vpngate plug-ins and its functionality?
Good Luck
P-B
SALICHAM
Post by SALICHAM » Sat Feb 25, 2017 2:54 pm
Thank you Pandora-Box
I downloaded again from http://www.vpngate.net/en/download.aspx it's helpful
Thank you so much
