It is currently Sun Aug 20, 2017 12:24 am
Post new topic Reply to topic  [ 1 post ]
Author Message
PostPosted: Sat Mar 18, 2017 6:02 pm
hello everyone! forgive me for bad english. i had a big problem with my laptop for years. sometimes my laptop gots hang up when i wanted it make sleep or hibernate. after many investigation i found that the problem is softether vpn / vpngate.
when i connect to vpngate via softether vpn with vpngate client, and after i disconnect and even i exit from softether vpn, i can't sleep or hibernate my laptop. when i press sleep or hibernate button, display get turned off but hardware (fan,cpu,hard...) and power LED didn't turned off and i must turn off with holding power button.
i experience this problem on windows 7 x86 and x64 and on all versions of softether vpn that i used since 4 years ago. now i'm on win7 x64 and the latest version of softether vpn+vpngate client.
please consider a bug fix or at least tell me what i must do to prevent hanging. i think it is a process that don't stop after connecting and cause to hang up.
thanks everyone for reading this!
best regards!
Top
 Profile
Search for:
Jump to:
Return to www.softether.org
