Missed data (ports and connect. type) in CVS List of servers
Gyfu
Post by Gyfu » Tue Jul 18, 2017 11:57 pm
Hi all, i was trying to do a script for this, but checking http://www.vpngate.net/api/iphone/ i found there is missed the ports and the connection type, is possible include that data?
Resume of missed data:
Ports (UDP and TCP) of SSL-VPN, OpenVPN, MS-SSTP
What type of connection support the server, SSL-VPN or L2TP/IPsec or OpenVPN, etc. or something to can recognize it.
In the CVS we only can find partial of the OpenVPN data (one port, the other missed), all other data missed.
Thx. Cya.
