how to set up softether client on a vps server
jeffmula
Post by jeffmula » Mon Aug 10, 2015 3:19 pm
How can i set up softether client on a vps and also daloRadius
GerryB
Re: how to set up softether client on a vps server
Post by GerryB » Wed Aug 12, 2015 2:50 pm
Depends on your VPS supplier how easy this will be, or what OS you are using on your VPS
Setting it up on UBUNTU Linux latest versions is easy enough. Its seems all the dependencies are present.
Following the instructions in the manual.
In fact on my VPS providers nodes Softethervpn has been the ONLY solution that has worked so far on Linux VPS. Set the firewall of course
I seem to remember that I was caught by not realizing tar xvf thesoftertherversionfile.gz created the directory below. So wget the installation file to /usr/local and /usr/local/vpnserver is then created.
Start vpnserver but it much easier to configure from windows server manager remotely. No password needed first time.
On a windows VPS is just like on any PC. Need to set the firewall of course. I find on Windows Softethervpn is 30% slower than the windows native VPN (PPPT etc) but they need the client to be free of firewall problems.
