Do you know wood plastic flooring?
Qizhenbi
Post by Qizhenbi » Tue Dec 27, 2016 5:34 am
 The wood-plastic composite board is made of wood (wood cellulose, plant cellulose) as the base material and thermoplastic polymer material (plastic) and processing aid, etc., and then mixed and heated and extruded by mold equipment. Of high-tech green materials, both wood and plastic performance and characteristics of wood and plastic can replace the new environmentally friendly high-tech materials, and has the same processing characteristics of wood, the use of ordinary tools can be sawing, drilling, Nails, very convenient, you can use the same as ordinary wood.[url=http://7trust.com/wpc-products/exterior ... e-decking/]Exterior WPC Composite Decking[/url]
  Wood-plastic flooring is a new environment-friendly wood-plastic composite products, in the production of high-density fiberboard produced in the process of wood phenol, by adding recycled plastic granulation equipment made of wood-plastic composite materials, and then extrusion production group Made of wood-plastic floor. At the same time with wood wood and plastic water-resistant anti-corrosion properties, making it a good performance and very durable outdoor waterproof anti-corrosion building materials. Both wood-plastic plastic water-proof and wood texture of the two characteristics, making it a good performance and very durable outdoor building materials (wood-plastic flooring, wood plastic fence, wood-plastic chair, garden or waterfront landscape ); Can also replace the ports, terminals and other wood components used, can also be used to replace the production of wood packaging, trays, warehouse pad plate, etc. too numerous to mention, uses a wide range.[url=http://7trust.com/eco-friendly-products ... ign-ideas/]Garden Decking Design Ideas [/url]
