It is currently Mon Aug 21, 2017 2:50 am
Post new topic Reply to topic  [ 1 post ]
Author Message
PostPosted: Thu Dec 29, 2016 10:17 am
Many industries, labor costs are very low, seedling production is one of them. But now, this situation is changing, labor costs are getting higher and higher. In this case, [url=http://roadrepairmachine.com/equipment/]Integrated maintenance vehicles[/url]
Raising the nursery is the most important part of the cost of sales to occupy a large proportion. The increase in seedling wages has prompted many nursery schools to use dredge rather than labor. For large acres on the nursery, the use of excavators can achieve efficiency and cost reduction. [url=http://roadrepairmachine.com/product/]Powder spreader[/url]
Dredging machine is crawler, the maximum speed of up to 20 km per hour. Automatic digging 15 cm in diameter trees, just 2 to 3 minutes, is more than 20 times the efficiency of artificial. Dredging machine hydraulic braking, high positioning accuracy, fast excavation, the destruction of trees is small, greatly improving the survival rate of trees.
Top
 Profile
Search for:
Jump to:
Return to www.softether.org
