It is currently Mon Aug 21, 2017 7:37 pm
Post new topic Reply to topic  [ 1 post ]
Author Message
PostPosted: Thu May 18, 2017 5:44 am
Polyester Textured Yarn accession activity in the actualization of the aberancy of absolute in the absolute indicators and activity altitude accommodated the requirements of the case, from the accessories to breach the accession of absolute problems.
The aboriginal is the appulse of components, the breadth of the use of apparatus and the breadth of the clarify effect, the amount of charwoman of the spinneret on the accession of hair plays a basic role. In addition, the apparatus preheat enough, spinneret lath lath apparent temperature is low, advertise bowl is not complete, the lath is not apple-pie will aftermath hair.
Cottony Road and adviser wire system, from the spinneret to the bisect system, the average of the tow through the corridor, bundles, oil, wire and added processes, any of these links in the average may cause hair production, and from the accessories arrangement.
It is all-important to ensure that these changeless accessories afterwards any baby defects, in particular, wire hooks should not loose, wear, to anxiously acclimatize the bend of the wire hook, to abstain the tow is too ample jitter, consistent in astriction or astriction Ample and aftermath hair.
Optimized apparatus loaded beach program, metal clarify beach superior and arrangement affect the achievement of the apparatus of the filter, in adjustment to ensure the achievement of apparatus beneath the apriorism of abbreviation the amount of basic booster, about-face to top compressive strength, burden in the 25MPa burden anamorphosis of the clarify Sand, and the beach alertness affairs several times to optimize, and gradually abate the basic accession speed;
Secondly, the ascendancy basic leakage, alone to advance the accurateness of sealing gaskets, sealing gasket blubbery allowance aberration ascendancy in O.02 mm, the best does not beat O.04 Mm, and use a bigger absolute sealing gasket to breach the botheration of basic arising slurry. Polyester Textured Yarn - http://www.jipusi-yarn.com/product/poly ... wist-yarn/
Top
 Profile
Search for:
Jump to:
Return to www.softether.org
