Can't delete or disable virtual network adapter
EnvY
Post by EnvY » Mon Sep 04, 2017 3:55 pm
Ok, so I recently installed SoftEther VPN Client and I created a network adapter as it required but after I restarted the program I can't do anything with the adapter (disable,delete) and I can't see it in my network settings either. I also can't create a new adapter becouse the program just freezes. I tried to reinstall the program but the same problem stayed.
Re: Can't delete or disable virtual network adapter
Post by thisjun » Thu Sep 14, 2017 7:44 am
Is there any security software on your computer?
I think it may block driver installation.
