can you please guide how can we do vpn through https proxy
thanks?
Re: vpn through https proxy
For what purpose? if you encapsulate https proxy within VPN tunnel, it will be easily registered by L7 and thus will be blocked.
you are wrong, i could did that and now work nice
every minutes that left, i found softether really multi purpose software for hack firewalls.
thanks alot from team
would you be kind enough and explain how you did it?
setup ccproxy on your server
configure your client at hostname at 127.0.0.1
configure client at mode http proxy at 443 and set your ccproxy username
go to advanced mode in client, set tcp connection at 8
enable half duplex mode.
disabe voip qos.
disbale encryption
enable data compression
disabe voip qos.
disbale encryption
