i am from china,yesterday,i used the software,it's very good,i can use others net,i am very happy,i can view facebook, and so on. But, today ,i can't through this software to sacn video and music,because the software can't work,it's wrong!
so,i need some help,i will provide some information!
thank you !
i think ,there are many mistakes in my words and sentences. i am sorry!
2013-05-22 20:02:30.994 VPN 连接设置 "VPN Gate Connection": 连接断开或连接失败。原因: 服务器连接失败。请检查网络连接,确保目标服务器地址和端口正确。 (代码 1)
2013-05-22 20:05:47.486 VPN 连接设置 "VPN Gate Connection": 连接断开或连接失败。原因: 协议错误。目标服务器返回错误。 (代码 2)
2013-05-22 21:15:39.566 ------------------------------------------------------
2013-05-22 21:15:39.566 SoftEther VPN Client Version 1.00 Build 9091 Release Candidate 3 (English)
2013-05-22 21:15:39.566 Compiled 2013/05/19 02:10:59 by yagi at pc26
2013-05-22 21:15:39.566 The SoftEther VPN Client Engine was started.
2013-05-22 21:15:39.829 Loading configuration file...
2013-05-22 21:15:39.830 Configuration file does not exist. Applying the initial settings.
2013-05-22 21:15:39.830 Monitoring the directory "e:\Program Files\SoftEther VPN Client1". If the amount of available free disk space becomes less than 8.00 GBytes, the backup files for log files and configurations that are saved on the sub-directories of this directory will be automatically deleted in the order of oldest first. The amount of free disk space that determines when to start deletion can be modified by changing the "AutoDeleteCheckDiskFreeSpaceMin" item in the configuration file.
2013-05-22 21:16:24.316 A new VPN Connection Setting "VPN Gate Connection" was created.
2013-05-22 21:16:56.169 A Virtual Network Adapter "VPN" was created.
2013-05-22 21:16:56.284 Connection processing for VPN Connection Setting "VPN Gate Connection" was started.
2013-05-22 21:16:56.284 VPN Connection Setting "VPN Gate Connection": Connection operation starting (this is now 1 times).
2013-05-22 21:17:12.209 VPN Connection Setting "VPN Gate Connection": The connection either was disconnected or it failed. Cause: Protocol error occurred. Error was returned from the destination server. (code 2)
2013-05-22 21:17:16.710 VPN Connection Setting "VPN Gate Connection": Connection operation starting (this is now 2 times).
2013-05-22 21:17:30.685 VPN Connection Setting "VPN Gate Connection": The connection either was disconnected or it failed. Cause: Protocol error occurred. Error was returned from the destination server. (code 2)
2013-05-22 21:17:34.114 The VPN Connection Setting "VPN Gate Connection" was deleted.
2013-05-22 21:17:39.006 A new VPN Connection Setting "VPN Gate Connection" was created.
2013-05-22 21:17:39.196 Connection processing for VPN Connection Setting "VPN Gate Connection" was started.
2013-05-22 21:17:39.197 VPN Connection Setting "VPN Gate Connection": Connection operation starting (this is now 1 times).
2013-05-22 21:17:49.220 VPN Connection Setting "VPN Gate Connection": The connection either was disconnected or it failed. Cause: Connection to the server failed. Check network connection and make sure that address and port number of destination sever are correct. (code 1)
2013-05-22 21:17:52.344 The VPN Connection Setting "VPN Gate Connection" was deleted.
2013-05-22 21:18:03.686 A new VPN Connection Setting "VPN Gate Connection" was created.
2013-05-22 21:18:03.849 Connection processing for VPN Connection Setting "VPN Gate Connection" was started.
2013-05-22 21:18:03.850 VPN Connection Setting "VPN Gate Connection": Connection operation starting (this is now 1 times).
2013-05-22 21:18:19.987 VPN Connection Setting "VPN Gate Connection": The connection either was disconnected or it failed. Cause: Protocol error occurred. Error was returned from the destination server. (code 2)
2013-05-22 21:18:22.377 The VPN Connection Setting "VPN Gate Connection" was deleted.
2013-05-22 21:18:31.928 A new VPN Connection Setting "VPN Gate Connection" was created.
2013-05-22 21:18:32.086 Connection processing for VPN Connection Setting "VPN Gate Connection" was started.
2013-05-22 21:18:32.086 VPN Connection Setting "VPN Gate Connection": Connection operation starting (this is now 1 times).
2013-05-22 21:18:42.111 VPN Connection Setting "VPN Gate Connection": The connection either was disconnected or it failed. Cause: Connection to the server failed. Check network connection and make sure that address and port number of destination sever are correct. (code 1)
2013-05-22 21:18:44.861 The VPN Connection Setting "VPN Gate Connection" was deleted.
2013-05-22 21:18:50.230 A new VPN Connection Setting "VPN Gate Connection" was created.
2013-05-22 21:18:50.329 Connection processing for VPN Connection Setting "VPN Gate Connection" was started.
2013-05-22 21:18:50.329 VPN Connection Setting "VPN Gate Connection": Connection operation starting (this is now 1 times).
2013-05-22 21:19:00.356 VPN Connection Setting "VPN Gate Connection": The connection either was disconnected or it failed. Cause: Connection to the server failed. Check network connection and make sure that address and port number of destination sever are correct. (code 1)
2013-05-22 21:19:02.809 The VPN Connection Setting "VPN Gate Connection" was deleted.
"2013-05-22 21:18:19.987 VPN Connection Setting "VPN Gate Connection": The connection either was disconnected or it failed. Cause: Protocol error occurred. Error was returned from the destination server. (code 2)" this error offen happyed,and i don't know how to slove it.
so,i write this article,and i hope someone to help me!
thank you !
who can help me to slove the problem?
Re: who can help me to slove the problem?
hi
please reStart your system and use another servers of vpn gate list
if there are firewall on your AntiVirus, disable it and try again
thank you
hyper wrote:
> hi
hyper wrote:
> hi
