I created a custom host name in the Dynamic DNS area on a test PC.
ie: "custom".softether.net
I later installed SoftetherVPN on the server it will run on permanently. When trying to use the custom domain name on the server. I tells me the name is already in use and choose a new hostname.
Thank you
DDNS host name reset
Re: DDNS host name reset
Hostname cannot be reused, you have to copy the old configuration files to the new server in order to keep the hostname.
Wich files in particular need to be restored ?
(I've the same issue)
