SofthEther with 2 NICS
raafat
Re: SofthEther with 2 NICS
Hello there! Technically speaking, this statement: "10.167.7.0/255.255.248.0" is a wrong statement. Most likely that network devices accept it but with a little change, which is modifying it as follows: "10.167.7.0/255.255.248.0" >> "10.167.0.0/255.255.248.0". So when you try to access your LAN from the remote side, your packets, actually, are destined toward your local router on the remote side because you don't have a routing entry for your LAN subnet, which is 10.167.7.0. Let me know if you can change your mask then I would further help you solving your issue.
Please try to push route to PCs of LAN side.
