windows client forbids rdp to that machine
testitout
Post by testitout » Wed Sep 13, 2017 5:31 pm
When I connect my pc with the softether client to a server. But when I connect to this server, I cannot connect to the pc with rdp or lan.
Is it possible to use the softether client, and still connect to that pc via lan?
Re: windows client forbids rdp to that machine
Post by thisjun » Tue Oct 17, 2017 4:51 am
What is 'the PC'?
testitout
Post by testitout » Tue Oct 17, 2017 6:35 am
it's a windows 7 rdp lan pc/computer
Post by cedar » Tue Oct 17, 2017 6:51 am
Is the PC same to VPN server?
Or it's in your local PC?
testitout
Post by testitout » Tue Oct 17, 2017 7:12 am
I have 2 situations and 2 identical pc's
pc 1: if softether is on on pc 1, I can connect to RDP via LAN to pc 2(this is oke).
pc2: when softether is on on pc2, I cannot connect to this pc from pc 1. It doesn't matter if softether is on on pc 1 or not.
both use client software to connect to the same softether server.
So it looks like I can only connect to a pc from Lan if softether is off on that pc. When I switch softehter on, the pc is unreachable from within Lan (RDP and network devices).
Post by cedar » Tue Oct 17, 2017 7:26 am
Do the local LAN and remote LAN use same network address?
It may cause malfunction.
testitout
Post by testitout » Tue Oct 17, 2017 7:47 am
no not at all, both adresses are different. I don't get why I can connect to lan if softether is on, but cannot connect to a pc within the lan when softether is on on that.
When softether is on connecting to that pc is impossible, but from the softether pc I can connect to the Lan.
Post by cedar » Tue Oct 17, 2017 7:54 am
Could you please show the IP addresses and network masks of the relevant hosts?
Could you show the result of executing "route print" at the command prompt during connection?
