DDNS hostname cannot be used when update to SoftEther VPN
jatan
Post by jatan » Sat Mar 09, 2013 5:22 am
Dear softether vpn San,
Please help me.
After update from packetix vpn 4.0 RC1 to softether vpn 1.0 RC2, the former DDNS hostname cannot be used anymore.
The "vpn_server.config" in packetix vpn folder has been deleted.
How could I get my earlier DDNS hostname? the hostname was "ParcTresor.vpnazure.net".
Thank you.
dnobori
Re: DDNS hostname cannot be used when update to SoftEther VP
Post by dnobori » Sat Mar 09, 2013 5:34 am
Hi jatan,
You can restore vpn_server.config from "backup.vpn_server.config" folder of PacketiX VPN 4.0.
jatan
Post by jatan » Sat Mar 09, 2013 5:43 am
dnobori wrote:
> Hi jatan,
Thanks Dnobori San.
However, the whole folder of packetix vpn4.0 has been deleted by mistake... So cannot find the "backup.vpn_server.config" folder, either...
dnobori
Post by dnobori » Sat Mar 09, 2013 5:45 am
Hi jatan,
You don't have any backups of config? If so, the private key to register on the DDNS host is lost.
I'm sorry I cannot help you if the private key has been lost.
dnobori
Post by dnobori » Sat Mar 09, 2013 5:47 am
You can try undelete software to recover the lost file.
jatan
Post by jatan » Sat Mar 09, 2013 6:19 am
Yes I tried but failed.
I will setup a new DDNS hostname then.
Thank you all the same.
