How to assign specific local ip for each client all time?
maffucci
Post by maffucci » Tue Mar 04, 2014 9:23 am
For ex,
Jacob 192.168.30.15
Aiden 192.168.30.16
Lily 192.168.30.17
..etc
sdevries.otn
Re: How to assign specific local ip for each client all time
Post by sdevries.otn » Mon Oct 13, 2014 2:31 pm
When you install SoftEther VPN client, it creates a MAC address for the virtual adapter. That is the MAC address you need to assign a static IP address too using windows, router, etc. Whatever acts as your current DHCP server. As far as I know, this MAC does not change once installed. If the computer gets wiped / reinstalled, this MAC will likely change, so be ready for that.
prince5
Post by prince5 » Wed Oct 22, 2014 8:23 am
MAC address is not the only way which may be used to assign static IP address to client, lack of assgining static IP to users is most need function in these giant VPN software
SoftEther VPN has almost all information for assigning static IP:
1- MAC address of SoftEther VPN Client (Look Virtual DHCP Server Status) - another choise to bind this information
2- Username/Password - another choice to assign static IP in username profile (Manage Users)
3- Username certificate - another choice to assign static IP (Individual Certificate Authentication Settings)
kosztyua
Post by kosztyua » Sun Mar 29, 2015 12:19 am
Only way to assign static IP is external DHCP or manually on the clients.
mrpine
Post by mrpine » Mon Aug 20, 2018 9:47 am
I have a windows 10 client. use l2tp/ipsec vpn connection. when I set manual ip address in vpn settings it got me error .
Any Help?!
This is server log
2018-08-20 13:27:49.891 L2TP PPP Session [172.16.5.202:1701]: Acquiring the networking information from the DHCP server failed. To accept a PPP session, you need to have a DHCP server. Make sure that a DHCP server is working normally in the Ethernet segment which the Virtual Hub belongs to. If you do not have a DHCP server, you can use the Virtual DHCP function of the SecureNAT on the Virtual Hub instead.
2018-08-20 13:27:50.043 L2TP PPP Session [172.16.5.202:1701]: The VPN Client sent a packet though an IP address of the VPN Client hasn't been determined.
2018-08-20 13:27:50.043 L2TP PPP Session [172.16.5.202:1701]: A PPP protocol error occurred, or the PPP session has been disconnected.
Re: How to assign specific local ip for each client all time?
Post by thisjun » Thu Sep 13, 2018 6:36 am
In the L2TP, the client can't specify an IP address.
First of all, MAC address should be fixed for each user.
Please refer to this topic.
viewtopic.php?f=7&t=61463
Then, please try third-party DHCP server that can assign a static IP address for each MAC address.
