VPN Clients Can't Connect to Server when in VPN
eli312
Post by eli312 » Mon Mar 10, 2014 8:20 am
I'm running SoftEther on Ubuntu and after setting up a simple hub have the following problem:
Clients can connect to the VPN and browse the internet fine (I've enabled SecureNAT as my host does not support Local Bridging). However, clients not only cannot communicate with each other, they cannot communicate with the server computer within the VPN.
Say, for example, I have three computers:
x.x.x.1: the server
x.x.x.10: one client
x.x.x.11: another client
x.x.x.10 cannot connect to x.11 or x.1, but can ping x.1
x.1 cannot ping or connect to either client
I don't have any security policies created, and am connecting to the VPN through L2TP+IPSec. I have SecureNAT and the internal DHCP server enabled, and they are working fine. I can't find any reason why the clients aren't able to communicate with each other. Any help would be much appreciated
Re: VPN Clients Can't Connect to Server when in VPN
Post by thisjun » Tue Mar 11, 2014 5:27 am
I can't understand meaning 'x.x.x.10 cannot connect to x.11 or x.1, but can ping x.1' x.x.x.10 can communicate with x.1 ?? (What does expression 'cannot connect' mean? Can not connect something software? )
Could you give me more information about network settings, which computer is in LAN, which computer is remote host(using VPN), and result of 'route' command etc.
Please read advise this topic before posting a question. http://www.vpnusers.com/viewtopic.php?f=7&t=2790 .
alfer
Post by alfer » Sat Sep 13, 2014 12:44 am
After struggling with this for the better part of a day I finally found the solution on an obscure post. I too was not able to connect to any services running on the server running SoftEther, although I was able to connect out to the Internet and to all other IP's on my LAN. To resolve this, like the documentation in section 3.6.11 says you have to create another physical interface. If you have a physical server that means installing another NIC if you dont have two already, in my case I'm using VirtualBox so I simply attached another virtual NIC to my VM's instance (which is attached to the same physical NIC on the host machine as the primary virtual NIC).
What the documentation doesn't tell you, is that this second NIC needs to be on a different subnet than your primary. So say your primary NIC's IP is 192.168.1.2, gateway 192.168.1.1. Your secondary NIC needs to be on for example 192.168.2.2, with gateway 192.168.2.1. Even though that gateway may well not exist (it doesnt in my case) this simple change fixed the problem and I am now able to SSH and access other services running on the VPN server. In Ubuntu 12.04 Linux I was able to modify my NIC config in /etc/network/interfaces to read:
auto eth2
iface eth2 inet static
address 192.168.2.2
netmask 255.255.255.0
gateway 192.168.2.1
dns-nameservers 8.8.8.8
Once your second NIC is up and running, just connect a local bridge from your virtual hub to the second NIC (eth2 in my case). You dont need to use a local bridge to the primary NIC, it is unnecessary. Hope it helps someone, and I also hope the fine developers at UoT can update section 3.6.11, and 11.1.2 of the manual to make this a bit more clear!
garnet
Post by garnet » Sun Feb 25, 2018 9:09 pm
Hi all
I have similar problem. I use IPSec and can connect to my VPN server running on raspbian on raspberrypi 3.
From client I can access the internet with my home IP (softether runs at home).
I can also ping the home gateway, in my case 10.10.10.1
My VPN server is 10.10.10.108 but I can not ping it at all.
I have one bridge between my vpn hub and eth0
Above solution didnt work.
What might be the problem?
Railtracer
Post by Railtracer » Tue Feb 27, 2018 6:51 pm
Garnet, this is a super old post, its more useful if you create your own post with a new topic.
In my own experience, when the vpn server only has one nic and is running a hub bridge off of it, clients that connect to that hub don't seem to have network connectivity to the server itself. I don't know the full explanation for this or if it is a bug, or a limitation of softether. What I do know is that the best practice for softether server is for the server to have a dedicated NIC for itself to use and receive connections on, as well as a dedicated NIC with protocols removed for the bridge to the virtual hub. When I ran in this configuration I was able to have clients ping the vpn server itself through the vpn, perhaps because their traffic is routed through a different NIC than the ping destination. This is just a guess. If your server is running on a pi 3 though, unless you are using a USB nic I would guess you are only using a single NIC for the server.
In the case of alfers response above, I think he may be slightly misled. The secondary NIC does not need to be on a different subnet. Ideally it has tcp protocols disabled and does not receive an IP address at all, and is a physical NIC dedicated to the task. I have used a single physical NIC, addressed as multiple virtual nics in a hypervisor for the purpose of having a dedicated virtual nic with disabled protocols, but since you are not running virtual, you need to add a physical NIC.
Long story short, read up in the tutorials, and work to follow softether best practices for the physical config of your server, you may get better results. There are legitimate reasons to use a second dedicated NIC, so I would find one that is compatible with rasbian and see if that makes the difference for you.
garnet
Post by garnet » Tue Feb 27, 2018 8:04 pm
Hi
It is an old topic, but very relevant. I hope someone from thenteam sees it and provide input. I can not add a second nic to the pi. Can i somehow use virtual nic?
qupfer
Post by qupfer » Wed Feb 28, 2018 8:09 am
Bind the vpn to a virtual interfact (tap_soft) and then use bridge utils and your network-configuration tool (like systemd-networkd) to create a bridge between the vpn/tap device and the physical device.
nianarona
Post by nianarona » Sat Mar 03, 2018 6:29 am
We can contact it from inside the LAN, but when I attach via VPN with my assessment laptop the tag determinations to the accurate IP address but there's no answer to ping requests. I recognize this functioned before, but I'm not sure how long it's been broken.
garnet
Post by garnet » Sat Mar 03, 2018 1:11 pm
I am not sure how to do this. Could you give some examples please.
I dont see any option to bind the vpn hub to a tap interface. Ingot one tap already but it doesnt show in the bridge options in softether.
