Hi, All:
I have a strange issue about SoftEther client and server.
I use a old NB to be a softether server, and its cmos batter is broken, So NB time is alwasy 1970/1/1, but my client is a PC which has normal time function.
The client on PC side cannot connect to NB server. but if I set time by manually
they work fine.
Is there any control option which can ignorse time ?
SoftEther and NTP Time issue.
Re: SoftEther and NTP Time issue.
Why do you not use ntp to set the correct time after a reboot?(ntpd -gq)
-g for ignoring any time-offset
-q for quit
-q for quit
