ipv4 over ipv6 vpn?
suntzu_2010
ipv4 over ipv6 vpn?
Post by suntzu_2010 » Sun Jul 27, 2014 10:51 am
All,
I have setup (softether build 9449) using ipv4 and everything works great. But, I need to move to an ipv6 connection (tunnel) and then ipv4 over the tunnel.
- The ipv6 tunnel is connecting and the server assigns a local ipv4 ip across the tunnel.
- The client can ping the server ipv4 gateway IP
- Howerver, the traffic is not being routed out the ipv6 gateway. The route injection does not seem to work on the client side... Using ipv4 everything is working???
What am I missing?
/s
Re: ipv4 over ipv6 vpn?
Post by thisjun » Tue Aug 12, 2014 5:22 am
Could you try to turn off IPv6 stuck on virtual NIC?
sara1112
Post by sara1112 » Tue May 15, 2018 7:10 am
hi have you solved this problem. now am in same problem could you help me please.. i want to configure ipv6 also
