softether with VPN Tracker 7
ch1731
Post by ch1731 » Tue Sep 23, 2014 10:45 pm
I am trying to get VPN Tracker 7 to function with SoftEther Server. I can get the connection ok but no traffic flows over the vpn and thus I can't get to the system. If I connect using the MAC built in VPN it works just fine if I use the "send all traffic over the vpn" settings.
Does anyone have any ideas what the issue might be? I appreciate any help you can give me.
Clay
qupfer
Re: softether with VPN Tracker 7
Post by qupfer » Tue Sep 23, 2014 10:55 pm
Use the build-in client?
ch1731
Post by ch1731 » Tue Sep 23, 2014 11:08 pm
I wish it was that easy. But the Mac OSX client although is easy to setup has a bad habit of only staying up for a short time before it drops. Sometimes its minutes other times its hours. The same problem occurs whether you are connecting to Cisco, Zyxel, Netgear. So our solution has been to use VPN Tracker which works great. But never having setup against a software client before I think I am missing something.
Thanks,
Clay
