RaspberryPi 3 with SoftEther as VPN gateway
Oceanwatcher
Post by Oceanwatcher » Sat Sep 23, 2017 2:06 pm
I am new in this forum and I have searched about my topic, but could not find any information about it.
Here is my idea:
Install Linux, Raspbian, on RaspberryPi 3. Install NTP.
Install SoftEther Client.
As SoftEther installs a virtual network adapter, I am thinking it should be possible to plug the RaspBerry into the switch and use it as a VPN gateway/router without adding another ethernet port. Just go into the network settings of any device on my network and change the IP of the gateway.
But how do I set up routing of incoming traffic on my ethernet port to the virtual VPN adapter?
Of course, the firewall needs to be adjusted.
ruimgoncalves
Re: RaspberryPi 3 with SoftEther as VPN gateway
Post by ruimgoncalves » Mon Sep 25, 2017 3:12 pm
Had a similar adventure, see if this helps you
http://www.vpnusers.com/viewtopic.php?f=7&t=6824
Oceanwatcher
Post by Oceanwatcher » Thu Oct 12, 2017 5:53 am
Thank you for responding!
For now, I got as far as installing the client. Your setup is for installing Softether Server and that is a bit different, but I still think I can learn some things from your setup.
Just wish there was a way to connect a GUI to the client on Linux!
Post by thisjun » Thu Oct 26, 2017 6:16 am
You can use with same way for VPN Server and VPN Client after creating tap device.
