[SOLVED][certificate error]I don't understand my setup
francoisp31
Post by francoisp31 » Tue Sep 26, 2017 8:31 am
Hello
I'm trying to make a vpn connection to my company and I failed to.
They given me a .vpn file containing the "setup to import"
So I started the VPN service as :
frs@tempo:/opt/vpnclient$ sudo ./vpnclient start
[sudo] password for frs:
The SoftEther VPN Client service has been started.
This is successfull of course
then I ran into vpncmd like that to check my setup :
VPN Client>VersionGet
VersionGet command - Get Version Information of VPN Client Service
Item |Value
Product Name |SoftEther VPN Client
Version Information|Version 4.20 Build 9608 (English)
Build Information |Compiled 2016/04/17 21:59:35 by yagi at pc30
Process ID |0
OS Type |Linux
VPN Client>Check
Check command - Check whether SoftEther VPN Operation is Possible
SoftEther VPN Operation Environment Check Tool
Copyright (c) SoftEther VPN Project.
All Rights Reserved.
If this operation environment check tool is run on a system and that system passes, it is most likely that SoftEther VPN software can operate on that system. This check may take a while. Please wait...
Checking 'Kernel System'...
Pass
Checking 'Memory Operation System'...
Pass
Checking 'ANSI / Unicode string processing system'...
Pass
Checking 'File system'...
Pass
Checking 'Thread processing system'...
Pass
Checking 'Network system'...
Pass
All checks passed. It is most likely that SoftEther VPN Server / Bridge can operate normally on this system.
VPN Client>
so here again all is OK.
I imported the file given to me (by the company)
step successfull
I check my nic was OK :
VPN Client>NicList
NicList command - Get List of Virtual Network Adapters
Item |Value
Virtual Network Adapter Name|VPN
Status |Enabled
MAC Address |00ACD139209A
Version |Version 4.20 Build 9608 (English)
VPN Client>
I add password & login informations with passwordset & usernameset commands
then I check the whole connection :
VPN Client>AccountList
AccountList command - Get List of VPN Connection Settings
Item |Value
VPN Connection Setting Name |XXXXXXXXXXXXXXX
Status |Connected
VPN Server Hostname |XX.XX.XX.XX:443 (Direct TCP/IP Connection)
Virtual Hub |XXXXXXXXXXXX
VPN Client>
Then I check connection status after running connect command
VPN Client>AccountStatusGet
AccountStatusGet command - Get Current VPN Connection Setting Status
Name of VPN Connection Setting: VPN Squad
Item |Value
VPN Connection Setting Name |XXXXXXXXXXXXXXXX
Session Status |Connection Completed (Session Established)
VLAN ID |-
Server Name |XX.XX.XX.XX
Port Number |TCP Port 443
Server Product Name |SoftEther VPN Server (64 bit)
Server Version |4.20
Server Build |Build 9608
Connection Started at |2017-09-25 (Mon) 17:59:14
First Session has been Established since |2017-09-25 (Mon) 17:59:15
Current Session has been Established since|2017-09-25 (Mon) 17:59:15
Number of Established Sessions |1 Times
Half Duplex TCP Connection Mode |No (Full Duplex Mode)
VoIP / QoS Function |Enabled
Number of TCP Connections |2
Maximum Number of TCP Connections |2
Encryption |Enabled (Algorithm: DHE-RSA-AES256-SHA)
Use of Compression |No (No Compression)
Physical Underlay Protocol |Standard TCP/IP (IPv4)
UDP Acceleration is Supported |Yes
UDP Acceleration is Active |No
Session Name |SID-FPUSSAULT-1644
Connection Name |CID-1xXXXX
Session Key (160 bit) |XXXXXXXXXXXXXXXXXXXXXx
Bridge / Router Mode |No
Monitoring Mode |No
Outgoing Data Size |276,130 bytes
Incoming Data Size |1,217,775 bytes
Outgoing Unicast Packets |0 packets
Outgoing Unicast Total Size |0 bytes
Outgoing Broadcast Packets |21 packets
Outgoing Broadcast Total Size |2,030 bytes
Incoming Unicast Packets |16 packets
Incoming Unicast Total Size |1,288 bytes
Incoming Broadcast Packets |5,414 packets
Incoming Broadcast Total Size |893,953 bytes
VPN Client>
But no connection is really established
This is confirmed by the log file containning that error messages :
2017-09-26 10:26:08.533 VPN Connection Setting "XXXXXXX": Connection operation starting (this is now 269 times).
2017-09-26 10:26:08.910 VPN Connection Setting "XXXXXXX": The connection has been either disconnected or it failed. Cause: User authentication failed. (code 9)
2017-09-26 10:26:23.902 VPN Connection Setting "XXXXXXXX": Connection operation starting (this is now 270 times).
& so on...
What do I mess ? or forgot to do ? or doing bad ?
There is no cohérent documentation for linux users ... so I am lost ....
Of course I already tried to reset ALL & restart from softether installation .
Help would be appréciated ..
Thanks
Regards.
francoisp31
Re: I don't understand my setup
Post by francoisp31 » Tue Sep 26, 2017 8:34 am
oh I've forgotten :
the file they gave to me is :
declare root
bool CheckServerCert false
uint64 CreateDateTime 0
uint64 LastConnectDateTime 0
bool StartupAccount true
uint64 UpdateDateTime 0
declare ClientAuth
uint AuthType 2
byte EncryptedPassword $
string Username $
declare ClientOption
string AccountName XXXXXXXXXX
uint AdditionalConnectionInterval 1
uint ConnectionDisconnectSpan 0
string DeviceName VPN
bool DisableQoS false
bool HalfConnection false
bool HideNicInfoWindow false
bool HideStatusWindow false
string Hostname XX.XX.XX.XX
string HubName XXXXXXXXXXXXXXXXXX
uint MaxConnection 1
bool NoRoutingTracking false
bool NoTls1 false
bool NoUdpAcceleration false
uint NumRetry 4294967295
uint Port 443
uint PortUDP 0
string ProxyName $
byte ProxyPassword $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
bool RequireBridgeRoutingMode false
bool RequireMonitorMode false
uint RetryInterval 15
bool UseCompress false
bool UseEncrypt true
of course with real informations instead of XXXX
but this is just looking good!? no?
francoisp31
Post by francoisp31 » Tue Sep 26, 2017 2:12 pm
Hello again,
My company had forgotten to give me the good certificate, (the CA one) ...
Thanks
Now it's ok of course after injection of the certificate with
VPN Client>CertAdd
CertAdd command - Add Trusted CA Certificate
Name of X.509 Certificate File to Register: CA-srv-VPN.crt
VPN Client>
