Need to hire a SE tech guru...
humpy
Post by humpy » Mon Oct 16, 2017 3:48 am
We have set up a small group of SE nodes and a main auth server, that is working.. to a point ..
However in fiddling with configs and connectivity have been having some issues.. eg like at moment have found we can use SE OR openvpn on the nodes. with our current sonfiguration .. but not at same time!!
Was hoping to engage a person who is very clued up with Soft Ether who knows what they are doing to help out with the configuration so it all works together as expected... when trying to find someone useful on upwork etc, no one there knows about soft ether!
Would be more ongoing consulting work i am sure.. Rates for work negotiable
Please msg if you think you can help...
cheers
will
