SoftEther client only connect when outside LAN
ARKO
Post by ARKO » Wed Nov 08, 2017 1:47 am
I'm testing SoftEther client on my notebooks, to connect outside the LAN. So what I want to do is:
1. SoftEther client starts before GPO is being applied
2. I want it to check if it's inside the LAN 172.25.0.1/24
3. When in LAN, don't connect and stop processing
4. When in WAN, connect VPN and go to step 5
5. First try SoftEther VPN protocol on port 5555
6. When step 5 fails connect to SSTP on port 443
Some questions:
1. Is this possible and is SoftEther really faster then SSTP
2. What is the best way to authenticate a domain computer to SoftEther VPN? Now I use NT authentication for domain users.
Re: SoftEther client only connect when outside LAN
Post by thisjun » Wed Nov 15, 2017 7:39 am
I think it's possible but toooo difficult.
It depends on environment. However, SoftEther is faster than SSTP usually.
I couldn't understand it. What problem did you have?
