Windows 7 pro 32 bit and 64 bit - weird problem with softether client
Moe
Post by Moe » Fri Nov 10, 2017 3:42 pm
I can connect to a commercial service using softether under almost any circumstance using the 64 bit machine.
But when I use the 32 bit Pentium M based gateway machine - it often fails to connect with an error code "2".
The pentium M machine connects to *some* VPN nodes - but not others. Have noticed no pattern and have become frustrated trying to isolate the cause.
Any tips appreciated.
Re: Windows 7 pro 32 bit and 64 bit - weird problem with softether client
Post by thisjun » Wed Nov 22, 2017 6:40 am
Is there any firewall on client side?
