AUTH_FAILED with password authentication.
I get AUTH_FAILED on OpenVPN, and can't connect with other protocols. I checked server logs and it shows authenticated successfully. Please help me setting up SoftEther Server on Amazon EC2 server. I can provide IP, username and password.
Re: AUTH_FAILED with password authentication.
Who is blocking you to use others methods ?
Tried L2TP and can't connect.
It's my problem, reinstalled SoftEther and used SoftEther VPN Client and connected. Thanks a lot.
I'm still having problems with OpenVPN, it gives AUTH_FAILED after pulling conf from server.
If you re-create a server certification, you should acquire new OpenVPN setting file from the VPN server.
