Speed is very slow although other VPN works fine?
ambt
Post by ambt » Sun Dec 17, 2017 11:24 pm
Hi there,
I'm new in the VPN world. I do have a cloud server (Ubuntu) and I have installed "OpenVPV Access Server" on my cloud server. The speed is very very high same as my actual speed internet.
I installed SoftEther on my cloud server, and I have few issues:
1- Is there a web interface for SoftEther?
2- Why the speed is really slow? (I only used it on my iPhone)
3- every time that my phone gets locked, the VPN connection turns off? every time I have to go to sitting and turn VPN on!!! OpenVPN doesn't do that.
4- is there a VPN app on Apple Store I can enter the SoftEther credential on and use it?
Thank you very much,
Re: Speed is very slow although other VPN works fine?
Post by thisjun » Fri Jan 05, 2018 5:01 am
There isn't.
What protocol do you use?
Why don't you use OpenVPN app?
There isn't.
