I upgraded Server from version 9505 to version 9529.
All OpenVPN clients have problem to connect. All my clients is running under OpenWRT linux.
/log:
Channel 0: Acquiring an IP address from the DHCP server failed. To accept a PPP session, you need to have a DHCP server. Make sure that a DHCP server is working normally in the Ethernet segment which the Virtual Hub belongs to. If you do not have a DHCP server, you can use the Virtual DHCP function of the SecureNAT on the Virtual Hub instead.
Channel 0: Failed to connect a channel.
/endlog
have you same problems?
How to downgrade server to version 9505?
OpenVPN clients not connecting
Re: OpenVPN clients not connecting
Downgrade to 9505 version solve this problem.
Can you tell me how to connect OpenVPN clients (with small configuration build) in new version?
What DHCP server do you use?
I also have DHCP problem.
I tried on version 9529 and 9546.
Sometimes can't get IP from virtual DHCP.
After restarting VPN server will be fine.
