How Enable IPv6 Service and Allocated Speed To Client
gengkai
Post by gengkai » Tue Feb 10, 2015 3:32 am
Greetings.
I want to ask on how to enable the IPv6 service using Softether VPN as I am sure that Softether support IPv6. Do I need to create DHCP for the server to distribute the IPv6 address? Can we allocated speed to the client from the server?
Thank you.
kh_tsang
Re: How Enable IPv6 Service and Allocated Speed To Client
Post by kh_tsang » Tue Feb 10, 2015 9:48 am
If you are using bridge to your LAN, you only need to configure your lan to support IPv6, no need configuration on the Virtual Hub.
kh_tsang
Post by kh_tsang » Tue Feb 10, 2015 10:06 am
There is one more method. To setup tap_device for each virtual hub, then disable the virtual NAT and use linux routing softwares and dhcp servers.
gengkai
Post by gengkai » Tue Feb 10, 2015 1:30 pm
Thanks kh_tsang for your reply.
I am using Windows Server 2008 for my server hosted by ramnode. Probably, Linux not applicable for Windows.
Is there anything that I need to configure at the VPN Server?
Thank you.
kh_tsang
Post by kh_tsang » Tue Feb 10, 2015 2:35 pm
Then you can try to use the vpn client to connect to the server itself to make an adapter instead of adding the tap device.
Set a static IP on the vpn adapter and tick no adjustment of routing table in the vpn connection settings.
gengkai
Post by gengkai » Wed Feb 11, 2015 5:08 am
Hello kh_tsang.
I did try your method and it works. But the things that I want is the client can have the IPv6 address allocated to the client automatically rather than client enter the IPv6 address manually at the VPN adapter.
Here's the result after I try using your method.
kh_tsang
Post by kh_tsang » Thu Feb 12, 2015 3:57 am
You can try to install DHCP server on your Windows Server, the one from Microsoft, and assign addresses on the vpn adapter using it.
vitaliksys
Post by vitaliksys » Tue Feb 14, 2017 2:43 pm
gengkai wrote:
> Hello kh_tsang.
can you help with setup ? please provide a comprehensive tutorial or contact me via skype - zosea.frosea
sara1112
Post by sara1112 » Mon May 14, 2018 1:35 pm
Hello kh_tsang,
I want to also configure softether ipv4 over ipv6.. I hope you did already this step , shall you share your stop what you did please
