OpenVPN Connection Error
Omid
Post by Omid » Wed Jan 03, 2018 6:47 pm
I am trying to connect to my SoftEther server using official OpenVPN client for Windows 10.
The connection cannot be established. On client side, I receive:
"SIGUSR1[soft,connection-reset] received, process restarting"
On server, here's the log file:
2018-01-03 13:38:33.978 On the TCP Listener (Port 443), a Client (IP address x.x.x.x, Host name "x.x.x.x", Port number 64434) has connected.
2018-01-03 13:38:33.978 For the client (IP address: x.x.x.x, host name: "x.x.x.x", port number: 64434), connection "CID-38-F089FDC620" has been created.
2018-01-03 13:38:34.806 OpenVPN Module: The OpenVPN Server Module is starting.
2018-01-03 13:38:34.806 OpenVPN Session 1 (x.x.x.x:64434 -> x.x.x.x:443): A new session is created. Protocol: TCP
2018-01-03 13:38:34.806 OpenVPN Session 1 (x.x.x.x:64434 -> x.x.x.x:443) Channel 0: A new channel is created.
2018-01-03 13:39:04.931 OpenVPN Session 1 (x.x.x.x:64434 -> x.x.x.x:443): Deleting the session.
2018-01-03 13:39:04.931 OpenVPN Module: The OpenVPN Server Module is stopped.
2018-01-03 13:39:04.931 Connection "CID-38-F089FDC620" has been terminated.
2018-01-03 13:39:04.931 The connection with the client (IP address x.x.x.x, Port number 64434) has been disconnected.
From the above log I cannot find out what is the problem.
Please assist.
Regards
Omid
Re: OpenVPN Connection Error
Post by thisjun » Wed Jan 17, 2018 5:44 am
Is there DHCP server on network of the virtual hub?
