Issue with VPN
attard.kurt
Issue with VPN
Post by attard.kurt » Tue Jan 09, 2018 7:48 pm
Dear All,
I used to work normally with softhervpn client using one of the vpn servers provided by http://freesstpvpn.com/. But all of a sudden today I noted the below error.
Error (Error Code 1):
Connection to the server failed. Check network connection and make sure that address and port number of destination server are correct.
I already carried out some research in which they suggested that it may occur due to time misconfiguration, but after checking confirmed that time is set properly even i tried to resync.
COuld you please help me
Regards,
Kurt
Re: Issue with VPN
Post by thisjun » Wed Jan 17, 2018 6:04 am
Please ask administrator of the service.
