SoftEther on Windows Server - Static IP?
vix
Post by vix » Sat Feb 28, 2015 5:41 pm
Hi, I have a dedicated server that I'm renting with about 20 different ip addresses on it, I want to install SoftEther on it and assign each one of my customers a different ip address (dedicated ip) how would I do this
I'm running windows server 2008 is there an easy guide I can follow, I'm not very tech savvy can someone link me please and how do I assign a customer a specific ip? Thanks for your help!
vix
Re: SoftEther on Windows Server - Static IP?
Post by vix » Sun Mar 01, 2015 7:44 pm
So I see this is the guide to install on windows
https://www.softether.org/4-docs/1-manu ... igurations
Looks simple enough but how do i assign a static ip to each customer?
vix
Post by vix » Tue Mar 03, 2015 7:11 am
anyone know?
vix
Post by vix » Sun Mar 08, 2015 7:12 am
would really appreciate any advice
Post by thisjun » Thu Mar 19, 2015 6:40 am
Do your ISP restrict access by MAC address?
kosztyua
Post by kosztyua » Thu Mar 19, 2015 10:43 am
I solved this by setting the IP manually on the client, and limiting the ability to only use that IP with the specific user. Still looking for a better solution.
Other solution may be setting up DHCP server and giving static assignment to the MAC addresses.
PacoBell
Post by PacoBell » Wed Mar 25, 2015 2:48 am
Doesn't SoftEther server come with a virtual DHCP server?
https://www.softether.org/index.php?tit ... HCP_Server
kosztyua
Post by kosztyua » Wed Mar 25, 2015 9:31 am
It does, but no static IP assignment function.
vix
Post by vix » Thu Apr 23, 2015 3:12 am
oh wow wish it had that, would make it so much easier
qupfer
Post by qupfer » Thu Apr 23, 2015 9:04 pm
SoftEther is a "Layer2" VPN, so its just a virtual "cable". IPs and so on are not Part of the VPN. Just some additional "compfort" function for the software.
So the best way is to useSoftEther vpn just like a "cable" and do all other stuff with optimized software.
In your case, use Windows-DHCP-Server.
Post by thisjun » Tue Oct 11, 2016 7:15 am
Access list can limit IP address for each user.
