Problem with SSTP VPN using Self Signed Certificates
qupfer
Re: Problem with SSTP VPN using Self Signed Certificates
Post by qupfer » Fri Mar 06, 2015 9:35 am
Post by thisjun » Thu Mar 19, 2015 6:16 am
SoftEther VPN doesn't support certificate authentication on SSTP protocol.
Firerouge
Post by Firerouge » Sun Aug 02, 2015 2:36 am
Belshackrela wrote:
> Will support be added any time in the near future?
Does anyone know the answer too this? MS-CHAPv2 isn't very secure.
kh_tsang
Post by kh_tsang » Sun Aug 02, 2015 2:42 am
I think you can try to get a Windows Server license to use SSTP on Windows Server.
Firerouge
Post by Firerouge » Sun Aug 02, 2015 9:07 am
> Server.
That's true, but you can't readily run Windows Server on a Raspberry Pi...
thunn
Post by thunn » Thu Oct 19, 2017 9:51 am
i can see that when using the softether client i can connect with SSTP and client certificate for authentication, but when im using windows build-in vpn connector im not able to, i know this is an old post but i hope that someone can help me/us
Post by thisjun » Wed Nov 01, 2017 6:51 am
SoftEther VPN Client doesn't use SSTP.
SoftEther VPN Client use native softether protocol.
SoftEther VPN Server doesn't support SSTP with cert auth.
