Use SoftEther VPN as Site to Site IP Sec Initiator
OSEMS
Post by OSEMS » Sat Oct 03, 2015 6:56 pm
we are evaluating SoftEther VPN at the moment. We are using gateprotect UTM Firewall at our main site. We are planning to use SoftEther VPN as site to site (lan to lan) endpoint at our other sites. We also need L3 routing.
Is it possible to set up SoftEther VPN as a remote site to site ipsec vpn initiator with a foreign product like gateprotect or sophos on central site?
(Ive attached some screenshots from gateprotect IPSec wizard, if this helps)
qupfer
Re: Use SoftEther VPN as Site to Site IP Sec Initiator
Post by qupfer » Mon Oct 05, 2015 10:14 am
no, this will not work.
Softether use L2TP/IPsec with IKEv1. (Layer2 Tunnel, secured with IPsec)
gateprotect use "direct" IPsec (Layer3).
OSEMS
Post by OSEMS » Tue Oct 06, 2015 8:11 am
qupfer wrote:
> Hi,
Ok, thank you. Hope this will be a feature soon.
theodisbutler
Post by theodisbutler » Thu Oct 08, 2015 12:53 am
Have you looked into the EtherIP / L2TPv3 settings?
