Disallow Password Save in Client security policy problem
The "Disallow Password Save in Client" security policy does not applies for users with "NT Domain Authentication" type authentication method.
Re: Disallow Password Save in Client security policy problem
Are you sure ? did you double check what are you doing ? make sure that you followed instructions correctly, ti's worthwhile doing that (:
Good luck
Good luck
Yes, I tested it many times. You can try it too. But as I see, this policy works with Standard Password Authentication method.
The policy apply for only standard password auth.
Yes, I see, but enabling to save the password in the VPN client with domain authentication method is problematical, because when the domain users's password expires, connecting with VPN client with saved (and expired) password locks out the user. Furthermore, when the user turns off the "Do not Save Password" parameter, there is no way to turn on it again even if she/he changed the password.
