I install the vpnserver and vpnclient on the same centos 7.1 system, and configure a client autoconnect to server, but the virtual network card always could not got the ip from the server, I can see the connect from vpncmd and ifconfig, I have to user dhclient to got the ip manually. I don't know why?
I try to using static ip, I created a ifcfg file in network-scripts directory, and set the static ip, netmask, gateway, network,etc. in it, but the virtual network card was not set to the static ip.
vpnclient do not got the ip address from server when connect
