VPN leak
kedikife
VPN leak
Post by kedikife » Tue Jan 16, 2018 10:24 am
Good morning and sorry for my poor english...
I'm testing SoftEtherVPN, and I'm in trouble.
The program seems to be good, but I have a problem...
If a connection trough a proxy fall (often the servers close connection), SoftEther doesn't stop all the connections, but still continue the job via provider (direct connection) loosing anonymity.
Is possible set SoftEther to avoid this? (if a proxy stop routing, stop ALL the connection to the computer).
Thanks.
kedikife
Browser setup
Post by kedikife » Tue Jan 16, 2018 5:49 pm
Good morning.
I would know if there is a way to manual set a browser to use with SoftEther Client (I know it isn't necessary since SE redirect the whole traffic).
Es. 127.0.0.1:80
I wold know it to FORCE the browser to use only the SE connection instead of ISP in case of broken proxy connection.
Thanks.
Re: VPN leak
Post by thisjun » Thu Jan 25, 2018 6:02 am
Please delete default gateway of ISP after connecting to the VPN server.
kuci
Re: VPN leak
Post by kuci » Fri Feb 02, 2018 3:59 pm
I have the same doubt and I've followed your suggestion.
When I change the ISP gateway settings the connection to the ISP goes down.
What is wrong?
Thank you.
diktus
Re: VPN leak
Post by diktus » Fri Feb 09, 2018 3:13 am
i dont understand why you still using proxy for anonymity while you use softether? it should be all traffic route to VPN server rather then a proxy.
If the connection route to proxy why do you use softether vpn?
Re: VPN leak
Post by cedar » Fri Feb 09, 2018 9:21 am
If connection goes down when ISP's default gateway is deleted, add route to proxy (or VPN server) manually to maintain route.
kuci
Re: VPN leak
Post by kuci » Mon Feb 12, 2018 3:10 pm
As Kedikife, I presume, I have the same problem (and also you!).
For diktus:
When SE is connected, everything is OK, but if the server disconnect, (and SE is still running) the traffic continue loosing privacy.
For cedar:
Could you explain batter please? (I'm novice).
I have to setting TCP/IP v4 to obtein manual IP address.
After connected SE I should delete the gateway of ISP, and then add the address of the proxy server???
kuci
Re: VPN leak
Post by kuci » Mon Feb 12, 2018 10:29 pm
To cedar:
Configured the connection manually, connected with SEVPN then substitute the gateway with the IP of the proxy connected.
Saving the new configuration the system show a message of error.
Reopening the windows the gateway is empty AND THE CONNECTION REMAIN STABLE.
BUT DISCONNECTING FROM PROXY, THE CONNECTION WITH MY ISP CONTINUE WORKING LOOSING PRIVACY.
diktus
Re: VPN leak
Post by diktus » Tue Feb 13, 2018 10:11 am
What proxy type do you use? Http proxy?
I think better you use manually proxy on browser. so the connection will like this
ISP --> SE --> Proxy via browser
kuci
Re: VPN leak
Post by kuci » Tue Feb 13, 2018 9:33 pm
"What proxy type do you use? Http proxy?"
I use the SEVPN proxy. They should be Socks5...
"I think better you use manually proxy on browser. so the connection will like this"
In this way I could use only programs that allow proxy settings.
SE proxies the full system.
The goal of this post is to avoid VPN leaks if SE proxy disconnect...
Do you know a way???
kuci
Re: VPN leak
Post by kuci » Wed Feb 14, 2018 7:29 am
SOMEONE WHO KNOWS THE DEVELOPERS OF SOFTETHER COULD ASKE THEM TO ADD THE FEATURE OF "BLOCK INTERNET TRAFFIC IF PROXY DISCONNECT" LIKE IN THE PROFESSIONAL PROXY SERVICES???
PLEASE.
fenice
Re: VPN leak
Post by fenice » Wed Feb 14, 2018 7:43 am
Do not post in capitals in a forum as it's considered SHOUTING and isn't acceptable.
These are community support forums manned by volunteers, if you wish to have a feature added or modified in the product then I'd suggest you go to github for this project and file an 'issues' with details of what you want.
Regards
Bill
kuci
Re: VPN leak
Post by kuci » Wed Feb 14, 2018 7:51 am
how can I contact them?
(I know what mean write in capitals,. I have done to add relevance to this message. As you can see, this is the only message in capitals).
fenice
Re: VPN leak
Post by fenice » Wed Feb 14, 2018 8:01 am
The details of the source repository are on the downloads page but here's the direct link: https://github.com/SoftEtherVPN/SoftEtherVPN
Posts in all capitals do not add relevance and they'll usually be ignored and the fact you only done it once is once too many.
Regards
Bill
kuci
Re: VPN leak
Post by kuci » Wed Feb 14, 2018 8:20 am
I've gone to github/issues but I haven't found a button Add New Issues.
I can only read new issues.
Have I to login? The registration is the seme to the forum? After signed appear a button Add feature?
fenice
Re: VPN leak
Post by fenice » Wed Feb 14, 2018 10:18 am
Create an account on GitHub and you can add new issues.
Regards
Bill
kda
Re: VPN leak
Post by kda » Fri Feb 16, 2018 6:57 am
Can you tell me how uninstall vpnclient.exe / uninstall SoftEther VPN?
Re: VPN leak
Post by thisjun » Thu Mar 01, 2018 8:00 am
wajywil
Re: VPN leak
Post by wajywil » Fri Jun 08, 2018 11:31 am
thanku
The board of the studies has been constructed for the students. All the ides of the board and ukbestessays order have been ensured with the help of the ideal paths. The route is set forth for the future ramifications.
whattheserver
Contact:
Re: VPN leak
Post by whattheserver » Sat Jun 09, 2018 6:03 am
> will like this"
Using something like proxycaps or foxyproxy for Firefox with tor/ssh socks proxy for the stuff your worried about leaking if Soft Ether goes down would be the ideal way to handle that.
What The Server- Your Privacy Solution Specialist
https://whattheserver.com
VPS/VPN/EMAIL
