DHCP configure - of addresses since x.x.x.100.
sergey113
Post by sergey113 » Fri Dec 25, 2015 4:04 pm
I use the version of the v4.19-9599-beta-2015.10.19-windows-x86_x64-intel.exe server on Windows 7 64-bit OS
The program works normally. Question: how it is possible to change the initial address from which IP to clients are given?
In a network already there is a personal computer with appointed manually IP. It would be desirable to have opportunity to adjust for the DHCP server on delivery of addresses since x.x.x.100.
So far the server gives out IP without mistakes. The conflicts of addresses weren't. It would be desirable to exclude possibility of the conflicts.
Re: DHCP configure - of addresses since x.x.x.100.
Post by thisjun » Thu Jan 07, 2016 7:18 am
Change the DHCP server configuration.
sergey113
Post by sergey113 » Thu Jan 07, 2016 8:56 am
how? I didnt find where to adjust.
shurick930
Post by shurick930 » Thu Jan 07, 2016 9:37 am
Hi Sergey :))
Is client's address given by softether or by DHCP server in your LAN?
AFAIK if address is given by softether's DHCP then you can adjust settings in softether's properties
and if address is given by LAN's DHCP server then you need to make on it a reservation for conflicting address....
sergey113
Post by sergey113 » Thu Jan 07, 2016 3:01 pm
Hi, shurick930 :)
Whether unfortunately I didn't do the analysis gave out this IP DHCP server of my router which is in a local network. I did a foolish think.
But by the form IP=192.168.1.254 this address gave out DHCP softether.
Router DHCP in a local network gives out IP since the address 192.168.1.10. It isn't enough clients in a network.
I didn't find in configuration manager a tab with the DHCP settings. Tell please where it?
Mistakes with purpose of IP weren't yet, but I am afraid that I can arise in the future.
shurick930
Post by shurick930 » Thu Jan 07, 2016 5:12 pm
If you use Virtual DHCP in softether, then you may find DHCP settings... I don't know exactly wehere they are because I don't use softether's DHCP and I new to softether..
But 192.168.1.254 is not given by DHCP, its fixed virtual interface of softether's router...
I think your client's addresses distributed by your LAN's DHCP server, not by softether.
P.S. maybe we can talk directly by email in russian? :)
sergey113
Post by sergey113 » Thu Jan 07, 2016 5:53 pm
Today access to a router is already closed. I didn't adjust remote access. Tomorrow I will check who exactly gives IP.
My e-mail: korolev_sa@list.ru
I am the novice user of softether. It is my first experience. I will look for settings in GUI.
Post by thisjun » Thu Jan 21, 2016 6:33 am
I think this topic will help you.
http://www.vpnusers.com/viewtopic.php?f=7&t=5396
