ip neigh -> fe80::2ae:ebff:fe00:aeeb dev vpn_vpn FAILED
TheRealYoussef
Post by TheRealYoussef » Tue Jan 16, 2018 11:28 am
I setup a SoftEther VPN server on my DigitalOcean droplet with SecureNatEnable and DhcpEnalbe. My Windows SoftEther client connects perfectly to the VPN server. I am unable to setup my Ubuntu 14.04 client however.
I installed the client, created NIC, and setup my account. Then:
$ ip addr show vpn_vpn
7: vpn_vpn: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
link/ether 00:ac:2b:b3:0d:52 brd ff:ff:ff:ff:ff:ff
inet6 fe80::2ac:2bff:feb3:d52/64 scope link
valid_lft forever preferred_lft forever
$ sudo dhclient vpn_vpn
inet 192.168.30.11/24 brd 192.168.30.255 scope global vpn_vpn
$ ip neigh
192.168.43.1 dev wlan0 lladdr 94:65:2d:70:60:fd REACHABLE
Why is this? And how do I fix it?
TheRealYoussef
Re: ip neigh -> fe80::2ae:ebff:fe00:aeeb dev vpn_vpn FAILED
Post by TheRealYoussef » Wed Jan 17, 2018 4:37 pm
Bump
qupfer
Post by qupfer » Wed Jan 17, 2018 7:49 pm
Your post is not very informatively. I even didn't know what your problem is? The fe80 Address? It's a self-assigned LinkLocal IPv6-Address. Absolute normally in IPv6 environments. If you want to "fix that" disable IPv6.
But I would guess, your problem is that you are unable to setup your Ubuntu 14.04 client? Probably because of your "sudo dhclient vpn_vpn" command.
You get a new gateway, that will change your default route. After that, your Linux system tries to send the encrypted packages through VPN --> will never arrive
So you should add a specific route to your server before running DHCP.
#!/bin/sh
vpn_ip=192.0.2.255 #of course, your real IP Address of your DO-Server
gateway=192.168.43.1 #of course, the IP Address of your local (not vpn) gateway
phys_device=eth1 # just to be sure, not needed if running before DHCP
sudo ip route add ${vpn_ip}/32 via $gateway dev $phys_device
