softether vpn tunnel keepalive message suppression
venkat.siva
Post by venkat.siva » Tue Jan 16, 2018 5:08 pm
I have VPN tunnel established between 2 ubuntu 16.04 PC, which has 8 connections b/w them.
Even if i dont sent any traffic via tunnel, i see 86KB of data per minute, i am not sure whether these are keep-alive messages or sync messages.
i see both TCP and UDP traffic transferred continuously, can you please help in suppressing these traffic.
Thanks,
Venkatesan.
Re: softether vpn tunnel keepalive message suppression
Post by thisjun » Thu Jan 25, 2018 6:05 am
Could you show more detail about configuration and network environment?
venkat.siva
Post by venkat.siva » Thu Feb 22, 2018 12:57 pm
Sorry for the delay,
declare GlobalParams
uint FIFO_BUDGET 10240000
uint HUB_ARP_SEND_INTERVAL 5000 <==================>
uint MAX_BUFFERING_PACKET_SIZE 2560000
uint MAX_HUB_LINKS 1024
uint MAX_IP_TABLES 65536
uint MAX_MAC_TABLES 65536
uint MAX_SEND_SOCKET_QUEUE_SIZE 2560000
uint MAX_STORED_QUEUE_NUM 1024
uint MEM_FIFO_REALLOC_MEM_SIZE 655360
uint MIN_SEND_SOCKET_QUEUE_SIZE 320000
uint QUEUE_BUDGET 2048
uint SELECT_TIME 256
uint SELECT_TIME_FOR_NAT 30
uint STORM_CHECK_SPAN 500
Is there a way to change the above config "HUB_ARP_SEND_INTERVAL" after i establish the tunnel.
My requirement is to change the tunnel setting dynamically without tearing down the connection.
Thanks,
Venkatesan.
Post by thisjun » Wed Mar 07, 2018 7:28 am
Is the traffic which you said ARP?
venkat.siva
Post by venkat.siva » Wed Mar 21, 2018 12:09 pm
Looks like yes, because when i set it to "60000", my idle tunnel traffic becomes very less.
Post by thisjun » Thu Mar 29, 2018 6:12 am
Could you try ' NoArpPolling' option?
http://www.softether.org/4-docs/1-manua ... ll_Packets
